freewing70
Feb 04, 2017Tutor
D7000 ANNOUNCED FW UPDATE: NEVER ARRIVED
Case #: 27710100 Case Summary: Readycloud: cannot upload files Product: D7000 Update from NETGEAR: Dear Mr. Girardi, Thank you for having enabled the Netgear support. Following feedback we ...
DarrenM
Mar 27, 2017Sr. NETGEAR Moderator
Hello Smoking84
I do not have any info on a date I will let you know if I get any new updates on this.
DarrenM
David_g
Apr 14, 2017Guide
I'm experiencing the same problem, and from a search on the forums I'm not the one. This router has been very expensive, it should have better support. I really do hope this gets solved, I've been using NETGEAR forever, would be a shame to switch brands. Can someone update us? Thank you.
