Actarus
Mar 29, 2022Aspirant
DDos attack: Teardrop
In questi ultimi giorni sto avendo problemi con questa tipologia di attacchi Ddos, specialmente con i servizi di Playstation Network nei giochi multiplayer online, sto cercando di capire se esiste un...
Actarus
Adesso.
[DoS attack: ACK Scan] attack packets in last 20 sec from ip [52.97.173.18], Tuesday, Mar 29,2022 17:10:36
[Service blocked: ICMP_echo_req] from source 5.252.73.37, Tuesday, Mar 29,2022 17:01:19
[Service blocked: ICMP_echo_req] from source 69.230.237.121, Tuesday, Mar 29,2022 16:37:30
[Service blocked: ICMP_echo_req] from source 151.106.171.1, Tuesday, Mar 29,2022 16:27:31
[Service blocked: ICMP_echo_req] from source 139.177.96.1, Tuesday, Mar 29,2022 15:54:49
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:35:50
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:35:50
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 15:35:50
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:35:49
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:35:49
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 15:35:49
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:35:48
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:35:48
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 15:35:48
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:35:47
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:35:47
[Service blocked: ICMP_echo_req] from source 103.150.18.146, Tuesday, Mar 29,2022 15:15:52
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:05:29
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:05:29
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 15:05:29
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:05:28
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:05:28
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 15:05:28
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:05:27
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:05:27
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 15:05:27
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 15:05:26
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 15:05:26
[Service blocked: ICMP_echo_req] from source 129.203.246.1, Tuesday, Mar 29,2022 14:58:35
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:48:15
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:48:15
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 14:48:15
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:48:14
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:48:14
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 14:48:14
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:48:13
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:48:13
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 14:48:13
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:48:12
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:48:12
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:29:05
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:29:05
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 14:29:05
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:29:04
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:29:04
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 14:29:04
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:29:03
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:29:03
[Service blocked: ICMP_echo_req] from source 95.172.68.56, Tuesday, Mar 29,2022 14:29:03
[Service blocked: ICMP_echo_req] from source 95.172.68.64, Tuesday, Mar 29,2022 14:29:02
[Service blocked: ICMP_echo_req] from source 95.172.68.62, Tuesday, Mar 29,2022 14:29:02
RaoD
Mar 30, 2022NETGEAR Employee Retired
Gentile Actarus,
Grazie per la sua riposta ed le ulteriori informazioni fornite.
Le chiederei di verificare che l'opzione "Risposta al ping sulla porta Internet in Configurazione WAN" sul suo D6400 sia deselezionata. Questa funzione se selezionata, consente di rilevare il suo dispositivo.
Inoltre, le chiedo di riavviare il suo dispostivo.
Rimango a disposizione.
Saluti,
Raony
Team NETGEAR
- ActarusMar 30, 2022Aspirant
RaoD ha scritto:Gentile Actarus,
Saluti,Raony
Team NETGEARSi ho controllato tutto il giorno e la voce è deselezionata.
- RaoDMar 30, 2022NETGEAR Employee Retired
Gentile Actarus,
Grazie per la sua risposta.
Mi permetta di poter investigare ulteriormente su le informazioni fornite.
Le scriverò appena possibile con un aggiornamento al riguardo.
Saluti,
Raony
Team NETGEAR- ActarusMar 30, 2022Aspirant
Saluti,
Raony
Team NETGEARLa ringrazio per la disponibilità, rimango in attesa di eventuali suggerimenti o informazioni.
Grazie.
