Alboscofelix's avatar
Alboscofelix
Follower
Apr 21, 2019
DGN2200v4 - DynDNS authentication failed
Hello Community.
I am trying to enable on my DGN2200v4 (firmware 1.0.0.82), the dynamic DNS using DynDNS. I have a valid dyndns account, with other working hostnames in use for other devices.
After following the configuration guidelines onthe DGN2200, actually simple, I checked if the configuration toward DynDNS is working using "show status" button and the message I get is "Authentication failed. User name or password is not correct."
Now, I'm 100% sure I set the right hostname, dyndns account name, and password.
I suspect the falure is due to DynDNS site asking for https connection to send account name and password, while DGN2200 is using http.
Do you have a suggestion how to fix this blocking issue ?
I also searched in the community archive but didn't find a solution.
I cannot even upgrade the firmware relase because rel. 1.0.0.82 seems the last one where VPN wizard is working, and I need to set up a VPN. Please, correct me if this wrong (tried with 1.0.0.90 and 1.0.0.108, and VPN wasn't configurable).
Thank you in advance.
Br, Alessandro
1 Reply
  • ElisabettaL's avatar
    ElisabettaL
    NETGEAR Employee Retired
    Gentile Alboscofelix,
    Benvenuto nella Community.
    Le chiediamo la cortesia di pubblicare in Italiano, in modo che tutti gli utenti possano capire ed eventualmente intervenire nel thread.
    La ringraziamo per la collaborazione.
    Saluti
    Elisabetta
    Team NETGEAR
