doriano
Mar 31, 2018Aspirant
NETGEAR ROUTER MODELLO D6000
Buon giorno ho un problema con l'aggiornamento del mio router _D6000 acquistati nel febbraio 2016 con Netgear Genie il firmware indica il router aggiornato alla versione V1.0.0.61 ma ho visto che n...
doriano
Apr 03, 2018Aspirant
Hello
the firmware update has been resolved by after that, if i use the app Netgear Genie on my desktop pc when i select the router setting box i rcvd the following answer: login failed the router response timed out
before the firmware upgrade the pc app properly well work
tks
Doriano
michaelkenward
Apr 04, 2018Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
- dorianoApr 04, 2018Aspirant
Hello
many tks Michael for the reply
before to reset the router factory settings, i have trying to use the genie via ethernet cable without wifi same answer
i think the problem is with the last firmware version 1.0.0.68 and the genie for desk top program 2.4.52
i think will be better to use an old version or if necessary connect the router via web..in that case i can see all without problems.now i have installde the last one
many tks again for help and kind rgds
Doriano
doriano
