MPP55
Mar 25, 2023Guide
ATTENZIONE all'upgrade del firmware per NBK752 (funziona ma...non sembra...)
Il mio sistema: NBK752 (Router 5G Orbi NBR750 + 3 satelliti RBS750). I tre satelliti sono "wired" e fino ad oggi tutto bene, sia funzionalmente sia nelle app (Windows e iOs) Oggi, seguendo quanto c...
MPP55
Mar 25, 2023Guide
Ho anche provato a fare un downgrade del firmware di un satellite alla versione precedente (fortunatamente avevo assegnato IP fissi e avevo username e password) collegandomi direttamente al loro IP via browser ma niente da fare!
Nella pagina dei devices dice che sono disconnessi ma funzionano perfettamente e lo dicono anche nella loro pagina...
Bel bug! Non sapere se funzionano e cosa hanno connesso...
- microchip8Mar 25, 2023MasterCool story, bro! Now in English!
- MPP55Mar 25, 2023Guide
Here it is…
My system: NBK752 (NBR750 router and three RBS750 satellites, wired to the router).
Everything was fine until yesterday.
Today I decided to update the Router’s and Satellites’ firmware. There are many report of possible security issues related to the old firmware.
I followed step by step the procedure: Orbi login, update manually a satellite at the time and finally the router.
Everything went fine. I noticed that the Router’s firmware number was different from the one for the satellites but they were both reported on the Netgear support page.
To make it short: the Orbi login reports that the three satellites are “disconnected” and so does the iPhone app.
The whole process went through the normal satellite light cycling (flash white, solid white, blue, OK) and finally I realized that they are working normally, extending the signal through the house, even if they appear “disconnected”.
Finally I got access to them through their IP address and their browser page says that everything is fine.
I even downgraded one satellite firmware to the previous without success.
Any idea?
