enzo-ita's avatar
enzo-ita
RBR350 IPoE per Sky WiFi
Hi,
I own a RBR760.
I want to connect directly to the ont.
My provider is Sky Italy.
I can find the configuration from Sky but I can not understand if the protocol required from Sky can be applied to my RBR760
If someone can help, will be appreciated.
Thanks
  • CrimpOn's avatar
    CrimpOn
    Can you please post the configuration information provided by Sky?
    The Orbi setup page first asks if the ISP requires a user name and password.  That is critical information.
    • enzo-ita's avatar
      enzo-ita
      Thanks for your answer. Here the traslation of the Sky instructions.
      To ensure that the modem you have chosen works correctly with the internet service offered by Sky, your device must meet the following minimum technical requirements:
      IPoE IPv4/IPv6 protocol
      NAT: MAP-T Mapping of Address and Port, Translation mode (RFC7599)
      Below are the Data session configuration parameters that you will need to set in your CPE GUI:
      Encapsulation: IEEE 802.1Q VLAN
      VLAN: 101
      Minimum technical requirements for FTTH:
      In the FTTH architecture, the optical fiber arrives directly into your home and must be connected to the ONT (Optical Network Termination) via the RJ-45 Gigabit Ethernet port.
      If your modem meets the minimum requirements indicated, after configuring the Data session as described above, it will be sufficient to connect it via the Ethernet cable to the ONT optical termination to be able to use the Data service.
    • enzo-ita's avatar
      enzo-ita
      VLAN: 101
