Gian64
May 02, 2019Aspirant
Compatibilita tra D6400 e OrbiRBK20
Esistono delle inompatibilità tra D6400 e Orbi RBK20 , al termine della procedura va giu' collegamento internet e non riesco a completarla.
- May 06, 2019
Gentile Gian64,
In una stessa rete non potrà utilizzare il D6400 ed il router del sistema Orbi RBK20 entrambi come router.
Valuti l'opzione di configurare il RBR20 come access point, maggiori informazioni.
SalutiFederico
Team NETGEAR
May 03, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
