Zetram
Feb 28, 2021Aspirant
Orbi Mesh Sistem + Switch Gigabit Managed
Buongiorno, vorrei collegare un Sistema WiFi 6 Mesh AX4200 (router e due satelliti) su diversi piani di casa tramite Backhaul per mantenere al massimo la connessione tra i vari dispositivi. La doman...
Feb 28, 2021Guru - Experienced User
I had my orbi satellites running through a managed switch and through an unmanaged switch. Without issues on either.
Some have had issues and had to disable igmp but I didn't have to. About all you can do is try it and see if it works with your gear.
