bebove
Aug 05, 2019Aspirant
Posso connettere IP Cam alla porta LAN del satellite di una rete Orbi ?
Ciao, posso connettere una IP Cam sulla porta LAN del satellite di un sistema Orbi configurato come Access Point, per farla comunicare con il router? Non sembra essere vista in rete.. Grazie!! Alb...
CrimpOn
Aug 05, 2019Guru - Experienced User
bebove wrote:Ciao, posso connettere una IP Cam sulla porta LAN del satellite di un sistema Orbi configurato come Access Point, per farla comunicare con il router? Non sembra essere vista in rete..
Translation: Hi, can I connect an IP Cam on the LAN port of the satellite of an Orbi system configured as Access Point, to make it communicate with the router? It doesn't seem to be seen on the net
In general, yes, an IP camera can be attached to a LAN port of a satellite, to a switch connected to the Orbi, or via WiFi. If the IP camera is configured to get an IP address using DHCP (asssigned by the router), then when connected it should appear on the Attached Devices display. Some IP cameras are designed to be attached directly to the Network Video Recorder (NVR), and some are designed to be powered over the ethernet cable (PoE) with power coming from the NVR.
The Orbi should be in AP mode if the goal is to have the IP camera communicate directly with the router.
Perhaps knowing the brand and model of IP camera would allow people to make further suggestions.
