madqwerty's avatar
madqwerty
Follower
Aug 22, 2018
Connecting an Ethernet Hub (or Switch) to a WiFi Extender with a single LAN port
Hello Community,
my question relates to ANY NetGear WiFi Extender with a single LAN port, not only the model selected when posting.
Is it possibile to connect an Ethernet Hub (or Switch) to a NetGear WiFi Extender with a single LAN port ?
Or I am forced to use a NetGear WiFi Extender with multiple LAN ports, discarding my present Hub ?
Thanks in advance,
Regards
Marco
1 Reply
  • EvelinaS's avatar
    EvelinaS
    NETGEAR Employee Retired
    Salve @madqwerty,
    Grazie per il suo post e Benvenuto nella Community! :)
    Si è possibile. Può utilizzare la porta Ethernet del WiFi Range Extender per collegare lo Switch.
    Cordiali Saluti,
    Evelina
    Team NETGEAR
