Davide88's avatar
Davide88
Potete di grazia rendere noto il comando su come montare readyshare su linux???
Salve,
è possibile rendere noto il comando funzionante per montare la condivisione readyshare su linux?
Le ho provate in tutte le salse senza riuscirci
davicom@server:~$ sudo mount cifs //192.168.1.122/USB_Storage /home/davicom/Desktop/untitled_folder 0 0
[sudo] password for davicom:
mount: bad usage
Try 'mount --help' for more information.
davicom@server:~$ sudo mount -t cifs //192.168.1.122/USB_Storage /home/davicom/Desktop/untitled_folder 0 0
mount: bad usage
mount: bad usage
davicom@server:~$ sudo mount -t cifs //192.168.1.122/USB_Storage/ /home/davicom/Desktop/untitled_folder
Password for root@//192.168.1.122/USB_Storage/:
mount error(2): No such file or directory
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/USB_Storage/ /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/USB_Storage/:  ****
davicom@server:~$ sudo mount -t smb -o username=guest //192.168.1.122/USB_Storage/ /home/davicom/Desktop/untitled_folder
mount: /home/davicom/Desktop/untitled_folder: unknown filesystem type 'smb'.
davicom@server:~$ sudo ufw disable
Firewall stopped and disabled on system startup
davicom@server:~$ smbd restart
[2020/12/23 14:28:36.991580,  0] ../../lib/util/debug.c:1098(reopen_one_log)
  reopen_one_log: Unable to open new log file '/var/log/samba/log.smbd': Permission denied
[2020/12/23 14:28:36.991610,  0] ../../source3/smbd/server.c:1775(main)
  smbd version 4.11.6-Ubuntu started.
  Copyright Andrew Tridgell and the Samba Team 1992-2019
davicom@server:~$ sudo smbd restart
davicom@server:~$ sudo ufw enable
Firewall is active and enabled on system startup
davicom@server:~$ sudo mount -t smb -o username=guest //READYSHARE/USB_Storage /home/davicom/Desktop/untitled_folder
davicom@server:~$ sudo mount -t cifs -o username=guest //READYSHARE/USB_Storage /home/davicom/Desktop/untitled_folder
mount error: could not resolve address for READYSHARE: Unknown error
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/USB_Storage /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/USB_Storage:
davicom@server:~$ sudo mount -t cifs -o //192.168.1.122/USB_Storage /home/davicom/Desktop/untitled_folder
mount: /home/davicom/Desktop/untitled_folder: can't find in /etc/fstab.
Password for root@//192.168.1.122/USB_Storage:  ***************
davicom@server:~$ sudo mount -t cifs -o username=admin //192.168.1.122/USB_Storage /home/davicom/Desktop/untitled_folder
Password for admin@//192.168.1.122/USB_Storage:  ***************
davicom@server:~$ sudo mount -t cifs -o username=admin //192.168.1.122/USB_Storage/prova /home/davicom/Desktop/untitled_folder
Password for admin@//192.168.1.122/USB_Storage/prova:  ***************
davicom@server:~$ sudo mount -t cifs -o username=admin //192.168.1.122/USB_Storage/prova/ /home/davicom/Desktop/untitled_folder
Password for admin@//192.168.1.122/USB_Storage/prova/: ***************
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/USB_Storage/prova/ /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/USB_Storage/prova/:
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/prova/ /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/prova/:
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122:\prova /home/davicom/Desktop/untitled_folder
mount error: could not resolve address for 192.168.1.122:prova: Unknown error
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122:\U /home/davicom/Desktop/untitled_folder
mount error: could not resolve address for 192.168.1.122:U: Unknown error
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/U\: /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/U::
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/U\:\prova /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/U:prova:
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/Usb_Storage /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/Usb_Storage:
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122\Usb_Storage /home/davicom/Desktop/untitled_folder
mount error: could not resolve address for 192.168.1.122Usb_Storage: Unknown error
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/Usb_Storage\U:\prova /home/davicom/Desktop/untitled_folder
Password for guest@//192.168.1.122/Usb_StorageU:prova:
davicom@server:~$ sudo mount -t cifs -o username=guest //192.168.1.122/Usb_Storage\U:\prova\ /home/davicom/Desktop/untitled_folder
mount: //192.168.1.122/Usb_StorageU:prova /home/davicom/Desktop/untitled_folder: can't find in /etc/fstab.
davicom@server:~$ sudo mount -t cifs -o username=guest \\READYSHARE\USB_Storage /home/davicom/Desktop/untitled_folder
mount.cifs: bad UNC (\READYSHAREUSB_Storage)
davicom@server:~$ sudo mount -t cifs -o username=guest \\READYSHARE /home/davicom/Desktop/untitled_folder
mount.cifs: bad UNC (\READYSHARE)
davicom@server:~$ sudo mount -t cifs -o username=guest \READYSHARE /home/davicom/Desktop/untitled_folder
mount.cifs: bad UNC (READYSHARE)
  • ErikaMa's avatar
    ErikaMa
    NETGEAR Employee Retired
    Buongiorno Davide88,
    dagli screen, sembra stia avendo problemi a installare il drive USB.
    Riesce ad accedere al drive da HTTPS o FTP (su Internet)?
    I link esatti sono mostrati nelle impostazioni ReadySHARE del router.
    Nel frattempo, le auguro buone feste!
    Saluti,
    Erika
    Team NETGEAR
  • ErikaMa's avatar
    ErikaMa
    Salve Davide88,
    i nostri esperti ci hanno inviato i passaggi seguenti per impostare USB_Storage su Ubuntu 20.10.; Gnome version 3.38.1:
    $ Sudo su
    - Inserire super user password
    # apt-get update
    # apt-get install cifs-utils (le più recenti distribution CIFS utility sono usate per lo sharing, la più vecchia versione Samba è obsoleta e non più in uso)
    Modificare il file fstab in etc. (per la prova è stato usato Nano editor):
    # Nano /etc/fstab (in Nano bisogna impostare il path dal router alla directory locale e settare i privilegi)
    Dopo aver inserito i path corretti, bisogna salvarli in Nano (Ctrl + O + Enter; Ctrl + X)
    $ Sudo mount-a (questo comando monterà il path sul suo computer al router, sarà possibile accedere da Nautilus)
    Le suggeriamo anche questo articolo.
    Saluti,
    Erika
    Team NETGEAR
