AleFonPal
Jun 19, 2017Star
RSync fail version 6.7.4
After installing version 6.7.4 on ReadyNas 312, backup file from Ready nas to another storage using Rsync doesn't work anymore. This is log. Can anyone help me? Backup Job Name: Pal02_rep Ba...
- Jun 23, 2017
Dopo l'aggiornamento è tornato a funzionare tutto correttamente.
Molte grazie.
AleFonPal
Jun 20, 2017Star
Ciao a tutti,
Dopo l'installazione della versione 6.7.4 su un ReadyNas 312, il backup dal ReadyNas verso un'altro server utilizzando Rsync non funziona più!
Segue il log con gli errori.
Backup Job Type: Incremental
Protocol: rsync
Backup Source: [volume:data]/
Backup Destination: [remote:rsync]/192.168.15.5::AleTest
Backup Start Time: Mon Jun 19 2017 19:25:53
Backup Finish Time: Mon Jun 19 2017 19:25:54
Backup Status: Success
sending incremental file list
sent 772 bytes received 121 bytes 1,786.00 bytes/sec
total size is 0 speedup is 0.00
L_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/ArtinfoMigrazione, ACL_TYPE_DEFAULT): Operation not supported (95)
data/BckConfig/
rsync: set_acl: sys_acl_set_file(data/BckConfig, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/BckConfig, ACL_TYPE_DEFAULT): Operation not supported (95)
data/CarLav/
rsync: set_acl: sys_acl_set_file(data/CarLav, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/CarLav, ACL_TYPE_DEFAULT): Operation not supported (95)
data/Caronte/
rsync: set_acl: sys_acl_set_file(data/Caronte, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Caronte, ACL_TYPE_DEFAULT): Operation not supported (95)
data/Commerciale/
sent 868 bytes received 4,267 bytes 3,423.33 bytes/sec
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.1]
EvelinaS
Jun 21, 2017NETGEAR Employee Retired
Gentile AleFonPal,
Grazie per aver scritto in Italiano. Provi a creare una cartella nuova e un nuovo backup. Il problema persiste?
Saluti,
Evelina
Team NETGEAR
- AleFonPalJun 21, 2017Star
Purtroppo si. Ho creato nuova cartella su un server di destinazione diverso e sul ReadyNas ho creato un nuovo BackupJob. Sempre lo stesso log di errore.
- EvelinaSJun 22, 2017NETGEAR Employee Retired
Grazie per la risposta.
Ora è disponibile la nuova versione del firmware 6.7.5:
https://kb.netgear.com/000038857/ReadyNAS-OS-6-Software-Version-6-7-5
Aggiorni il suo ReadyNAS e verifichi il funzionamento del Backup. Se la problematica si ripresenta, la prego di inviarmi tramite un messaggio privato gli screen shot con le impostazioni relative al backup.
Rimaniamo in attesa di sue notizie.
Saluti,
EvelinaTeam NETGEAR
