Patrick100
Aug 15, 2024Aspirant
2 routers. Can't attache the cable modem to the new Netgear
I just purchased a RS300. After unplugging the ethernet cable from my old router (the cable that goes to the modem) and into the RS300 I could not get an internet connection. If I keep the old router...
Patrick100
Aug 16, 2024Aspirant
Thank you for your reply.
I understand - I'm not very skilled in this type of thing.
It's modem only no Router or LAN ports.
I have an Ethernet switch attached to the LAN port of the Asus router. The Netgear is attached to one of the switches LAN ports.
The WiFi client looses connection to the Netgear. It will connect initially but fails within a few seconds.
Sometimes the Internet light on the Netgear stays on (connected) other times it drops the internet connection (indicating no connection)
Only one pic allowed at a time right now. Let me know if you need another of the front of the modem.
The additional 'thin wire" you see is for voice. I'm sure you knew that though.
Aug 16, 2024Guru - Experienced User
So if you power OFF the modem, then disconnect the ASUS router from the modem and connect the RS router to the modem, power ON the modem then power ON the RS, Does the RS then work?
I believe that's a base modem Hitron modem.
