Patrick100
Aug 15, 2024Aspirant
2 routers. Can't attache the cable modem to the new Netgear
I just purchased a RS300. After unplugging the ethernet cable from my old router (the cable that goes to the modem) and into the RS300 I could not get an internet connection. If I keep the old router...
Aug 16, 2024Guru - Experienced User
Can you take a picture of the modem and posted please? Back ethernet ports please.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Be aware that most ISP modems only support having 1 router connected, thus you can't have two routers connected.
Patrick100
Aug 16, 2024Aspirant
Thanks for your reply.
I I did posted a pic just now.
I did try a couple of cables. One new and one from another working device.
Neither made a difference.
I have tried power cycles several times. I can't be sure I did one in the exact sequence you recommended but I'll do that as soon as I can and post the results.
- FURRYe38Aug 16, 2024Guru - Experienced User
Let us know...
