Patrick100
Aug 15, 2024Aspirant
2 routers. Can't attache the cable modem to the new Netgear
I just purchased a RS300. After unplugging the ethernet cable from my old router (the cable that goes to the modem) and into the RS300 I could not get an internet connection. If I keep the old router...
Patrick100
Aug 16, 2024Aspirant
Thanks for your reply.
I I did posted a pic just now.
I did try a couple of cables. One new and one from another working device.
Neither made a difference.
I have tried power cycles several times. I can't be sure I did one in the exact sequence you recommended but I'll do that as soon as I can and post the results.
Aug 16, 2024Guru - Experienced User
Let us know...
