AGarcia99's avatar
AGarcia99
3500 sq ft home coverage with the new RS700
I am planning on purchasing the best wireless routing equipment I can find to us with my Charter Spectrum service, since I have had serious issues with the wireless router I rent from them.  My home is a 3200 square foot home with at least 6 streaming TVs and 5 additional wireless devices.  Optionally, I would like to have wireless capability in my backyard.  Would you recommend the new Nighthawk RS700 or any of the Orbi Mesh systems?
  • FURRYe38's avatar
    Since the RS hasn't released to the public yet. There's little or no experiences out there yet to give you feedback on the RS700.
    The RS and other Orbi systems are intended for inside or indoor use. With some coverage out doors say anywhere from 10-20 feet beyond the building exterior walls based on building materials as well.
    For that size of home a Orbi 7,8 or 9 series would work with the main router and just 1 RBS. I have a 5000sq ft home and can get away with 1 RBS with power set to full strength. If I run two RBS which I do, I turn down the power to 25% most of the time.
    You can have too much wifi as well: https://youtu.be/UR0viMLISz4
    Placement and distances of any MESH system is key. What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
  • michaelkenward's avatar
    michaelkenward
    Try plugging your details into these places.
    Wireless Routers for Home | NETGEAR
    and
    Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
    Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
    You don't say how fast the Internet connection is. Might be a useful  extra detail. Lots of streaming there, especially if they are all running at the same time.
    • AGarcia99's avatar
      AGarcia99
      Forgot to mention that it's a 2 story home running on an internet connection of 500m speed. Thinking about increasing to 1g.
      • FURRYe38's avatar
        I would first try a Orbi 7 or 8 series. I have 1Gb here. Both work great.
  • Compared to other brands like MI and Tp-Link routers, we get more durability on Net gears. I am totally impressed with their coverage and quality.
