Danglez83
Jun 06, 2024Follower
5ghz Randomly Disappears
This is the second time this has happened. Seemingly out of nowhere, my 5ghz network band just disappears from my network. My only options are 2.4 and 6 (limited). I do not use smart connect due to m...
jonathan16833
Jun 18, 2024Guide
Hello,
I just came here to say the same thing. I have to keep rebooting my router for 5ghz to show up I just rebooted yesterday and it's not working today so I am not even sure how long it was working correctly. The only thing I have changed is I started using my laptop on the 6e 6ghz band. I can't think of any other reason the 5ghz band keeps disappearing as I never had this issue before. It will not show up on any devices iphones pcs .
BH_C
Jun 19, 2024NETGEAR Expert
Can you share the complete screenshot of the 5GHz tile on the Web GUI / ADVANCED tab dashboard like this?
- jonathan16833Jun 19, 2024Guide
Here you go
