Spicyalan
Feb 01, 2024Follower
Abnormal IP and connection failure after disabling smart connect - RS700
RS700 - Firmware Version V1.0.7.82_2.0.80 After disabling the smart connect (which means separate the 2.4Ghz, 5Ghz, and 6Ghz), all the mobile devices can't connect to the router, and the devices get...
BH_C
Feb 01, 2024NETGEAR Expert
We have a trial firmware that may fix this issue? would you like to give it a try?
I will PM you the firmware link. Thanks.
