Floorboss
Mar 23, 2025Follower
BE 19000 RS 700 router latency
Few months back my latency was very good like 12 ms. Now it's like 30ms or higher when you do the speed test. Xfinity charged me 100 dollars and said it was my router that everything was fine on their...
Mar 24, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Have you tested latency with a wired PC connected directly to the ISP modem/ONT?
Be sure you have WiFi 7 and 6Ghz supporting devices.
Is Protection Engine enabled on the router? Try disabling it.
