Floorboss
Mar 23, 2025Follower
BE 19000 RS 700 router latency
Few months back my latency was very good like 12 ms. Now it's like 30ms or higher when you do the speed test. Xfinity charged me 100 dollars and said it was my router that everything was fine on their...
ShadowMario3
Mar 24, 2025Luminary
If you're on cable with Comcast, there probably isn't much that you can do in terms of making the ping better other than making sure you're hardwired to the router. Switch over to fiber if you want better ping overall.
If you're not seeing WiFi 7, make sure your phone can actually support it.
