Squeeks99's avatar
Squeeks99
BE18000 RS600 Tri-band SSID Issue
I just bought the BE18000 RS600 Tri-band WiFi 7 router and no matter what I try during configuration (either Web or Nighthawk app) I cannot disable the SSID.   Using the Web interface I uncheck the...
  • FURRYe38's avatar
    Dec 28, 2024
    All check boxes  for each radio have to be unchecked for each radio for all fo them to be disabled. How I have mine currently. đŸ˜‰
