klee608
Nov 18, 2024Guide
BE9200 sending BPDU out wan port
Device is sending put BPDU on the wan port. This is causing the service provider switch to put the port into blocking state as they are not expecting an access port to receive BPDUs. Is there a settin...
Nov 19, 2024Guru - Experienced User
How are you determining this is coming from the router?
What is BPDU?
RS###?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
