klee608
Nov 18, 2024Guide
BE9200 sending BPDU out wan port
Device is sending put BPDU on the wan port. This is causing the service provider switch to put the port into blocking state as they are not expecting an access port to receive BPDUs. Is there a settin...
Nov 19, 2024Guru - Experienced User
1. BE9200 isn't a model. What device do you have?
2. BPDU is mainly a feature of managed switches. Are you using a managed switch?
3. How is your network setup (The gateway/switches/router)?
4. I've never seen bpdu on a consumer device. I'd be suspicious of the other devices on your network or whatever you have wired into the wan port
klee608
Nov 19, 2024Guide
The device is model RS280. The sticker on the bottom says BE9200 model rs280. This router is attached to a Cisco switch. The port is configured as an access port. I know it sent a BPDU because the Cisco switch reported that it received a BPDU.
*Nov 19 02:48:28.455: %SYS-5-CONFIG_I: Configured from console by console
*Nov 19 02:49:36.591: %SPANTREE-2-BLOCK_BPDUGUARD: Received BPDU on port Gi1/1 with BPDU Guard enabled. Disabling port.
*Nov 19 02:49:36.591: %PM-4-ERR_DISABLE: bpduguard error detected on Gi1/1, putting Gi1/1 in err-disable state
*Nov 19 02:49:54.699: %SYS-5-CONFIG_I: Configured from console by console
*Nov 19 02:50:25.571: %SYS-5-CONFIG_I: Configured from console by console
*Nov 19 02:50:38.063: %SYS-5-CONFIG_I: Configured from console by console
*Nov 19 02:50:42.643: %SPANTREE-2-ROOTGUARD_BLOCK: Root guard blocking port GigabitEthernet1/1 on VLAN3101.
*Nov 19 02:55:47.427: %SYS-5-CONFIG_I: Configured from console by console
- plemansNov 19, 2024Guru - Experienced User
Wonder if the bpdu is misinterpreting something. Might try disabling it on that port.
- klee608Nov 19, 2024Guide
My ISP will not disable bpduguard and guard root on their cisco switch. I took a wireshark capture and it is a BPDU from the netgear. I can see the netgear's MAC address in the source.
 - FURRYe38Nov 19, 2024Guru - Experienced User
What model# is the Cisco switch?
Happens with a different switch, something on managed?
