klee608
Nov 18, 2024Guide
BE9200 sending BPDU out wan port
Device is sending put BPDU on the wan port. This is causing the service provider switch to put the port into blocking state as they are not expecting an access port to receive BPDUs. Is there a settin...
BH_C
Nov 19, 2024NETGEAR Expert
Thanks klee608 hexcei for reaching out to us and thanks FURRYe38 for tagging me.
I'm not aware that we send BPDU packets or even layer 2 protocol packets (except for ARP) from the Internet port, we will look into it.
In the mean time, klee608, appreciate it if you can send me your wireshark capture. Thank you.
klee608
Nov 20, 2024Guide
Here are two wireshark captures. One of the capture has bpduguard disabled on the cisco switch and the other one has bpdguard enable.
I cannot upload .pcapng files. Here are links to the files.
