klee608
Nov 18, 2024Guide
BE9200 sending BPDU out wan port
Device is sending put BPDU on the wan port. This is causing the service provider switch to put the port into blocking state as they are not expecting an access port to receive BPDUs. Is there a settin...
klee608
Nov 20, 2024Guide
Thanks for the info. I'm pretty close to following your footsteps.
BH_C
Nov 20, 2024NETGEAR Expert
OK, we can see the issue. We will have trial firmware with the fix shortly. If you would like to give it a try, I will PM you a link to download the trial firmware when it's ready. Thank you.
- klee608Nov 21, 2024Guide
Yes, I would like to test. Please provide this as soon as possible.
