klee608
Nov 18, 2024Guide
BE9200 sending BPDU out wan port
Device is sending put BPDU on the wan port. This is causing the service provider switch to put the port into blocking state as they are not expecting an access port to receive BPDUs. Is there a settin...
BH_C
Nov 28, 2024NETGEAR Expert
Hi klee608 , I've sent you a PM with the link for the trial firmware that should have fixed the BPDU issue. Thank you.
klee608
Nov 28, 2024Guide
Thank you. I will give this a try on Monday after the holiday.
- FURRYe38Dec 19, 2024Guru - Experienced User
- klee608Dec 19, 2024Guide
The new firmware works. I'm no longer seeing BPDUs from the nighthawk.
Thank you.
Glad it's working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
