baybreezeg
Mar 14, 2026Aspirant
BE9300 Broken With 4kQAM Rate Set On BE200
So this is an interesting and very specific phenomenon I've narrowed down. The BE200 from intel and the BE9300 from Netgear completely bomb out their rate set negotiation when the signal is perfe...
sonofgohan
Mar 15, 2026Tutor
It means there is likely a compatibility or firmware issue between the Intel BE200 and Netgear BE9300 when using 4K-QAM. When the signal is too strong, the devices fail to negotiate the rate properly, causing poor performance. Lowering the signal forces a lower QAM rate, which works normally.
