baybreezeg
Mar 14, 2026Guide
BE9300 Broken With 4kQAM Rate Set On BE200
So this is an interesting and very specific phenomenon I've narrowed down. The BE200 from intel and the BE9300 from Netgear completely bomb out their rate set negotiation when the signal is perfe...
baybreezeg
Mar 15, 2026Guide
I should also mention the BE200 runs fine if forced to AX mode down from BE in this case.
It is what leads me to believe there is a 4kqam negotiation issue or RU allocation issue or the router is getting confused handling the different capabilities of iphone 16s and BE200s on the same network.
