Bataaf's avatar
Bataaf
Can the RS500 (BE12000) be used in wireless bridge mode?
All the information on the NetGear site seems to imply that it can be used in wireless bridge mode, BUT there is not wireless bridge mode on the Advanced Settings page. There are only 2 modes: Router and AP.
  • No. I asked about this. Wireless Bridge is not coming to the RS series. Sadly. đŸ˜•
  • FURRYe38's avatar
    • Bataaf's avatar
      Bataaf
      Thank you. That was an expensive mistaken purchase. Especially as I tried my utmost to make sure that it would be able to do it. I now have an essentially useless wireless router.
      This should be prominently stated in the advertising and on the product page, especially since it deviates from almost every other NetGear wireless router, and the NetGear website chatbot.
      • FURRYe38's avatar
        Did you first contact NG to see if it was a feature before you bought it?
        The RS is not really worthless, just doesn't have the bridge mode. It's designed as intended. Would be nice to have.
        Seems like bridge mode is not a highly used feature and may have been not included in the RS series.
        And with MESH being NGs end result, this forth coming feature maybe what NG wants for the RS series and focus on.
