drkayak99
Sep 19, 2024Aspirant
cannot disable broadcast of 6GHz SSID on RS700S
Hi, Because none of my devices support 6GHz, I want to disable broadcast of that SSID. I uncheck 'Enable SSID Broadcast' for the 6GHz network under WIreless Setup, and click on Apply. Inevitabl...
- Sep 21, 2024
It now appears that the 'Enable SSID broadcast' is staying unchecked for the 6GHz network, which is what I wanted.
Sorry for wasting people's time!
Sep 21, 2024Guru - Experienced User
Is the Front 6Ghz LED turn OFF and remain OFF after you disable the 6Ghz SSID network?
drkayak99
Sep 21, 2024Aspirant
- FURRYe38Sep 21, 2024Guru - Experienced User
Enjoy. 📡
