jonathan16833
Jan 19, 2024Guide
Cannot Stay connected to Wifi 6 also 6ghz not available
Hello, I have two devices with the same network adapter (intel ax210) which supports 6ghz. One is my pc and one is my laptop, the laptop always struggles to stay connected at 2402 Mbps and always...
Jan 21, 2024Guru - Experienced User
If you're on windows, you should be able to go into the device manager and set the preferred band. I've done that on my laptop to better test 6ghz.
