Router2371
Aug 02, 2026Aspirant
Cannot Turn off Smart Connect!
Honestly, about ready to just be done with this RS500 router. Today, it decided to turn on Smart Connect all by itself....we suddenly could not find our network SSIDs. Logged in, found that Smart C...
Aug 03, 2026Guru - Experienced User
Which browsers did you try? MS Edge, Firefox or Opera?
Can you access it by using the Nighthawk mobile app?
Can you select manual channels 1 and 40 or 11 and 48?
Can you disable the wifi radios all together?
How about powering OFF the router for 30 seconds then back ON?
Brand and model# ISP modem/ONT that the RS router is connected too?
Router2371
Aug 03, 2026Aspirant
Not sure what Opera is, but Edge, Firefox, Chrome, also private windows for each of those.
Noted earlier, the app does not have any controls for smart connect
Channels I can select but since SC is on, I cannot separate out the SSIDs, pw, or choose what bands I want devices to connect to.
I did turn off the radios, back on...hid the ssids, and even installed last version of FW. no change. so I updated back to current fw.
I have turned the router off and on so many times now I cannot even remember lol. every time, it comes back locked on SC, cannot turn it off.
Modem is my Moto MB8600, has always been fine. like i said, this just happened out of nowhere midday yesterday. we were in living room, suddenly lost wifi. noone could find their ssids. logged in, saw SC was now on, and we cannot turn it off. It just did it all on its own while we were just playing a board game.
- FURRYe38Aug 03, 2026Guru - Experienced User
And if you factory reset and router and setup from scratch using a wired PC and web browser?
The router would not auto re-enabled this on it's own. Anyone else have access or used the NH app to connect to the router?
- Router2371Aug 03, 2026Aspirant
Nooone else has access. It is just my wife and I and it is secured and we are secluded. The router did it on its own....there is something wrong with it, clearly....it did not just turn on, it is completely locked, cannot be turned off, as I showed in my picture. There is no option to turn it off. That should not be the case.
I have not tried a factory reset yet, as have been hoping to avoid that bc having to redo the whole setup will take hours again.
You'll need to reset and setup from scratch. Can use same SSID names and PWs for the wifi as you walk thru the setup wizard and I think you can disable SC during it's process there to set up separate SSID names. Once you have the router set up again, be sure to save off a back up configuration to file. In case a reset is needed you'll have a quick way to get it back up and running.
I'd open a support ticket on this with NG support as well.
