jsmcbn
Mar 03, 2025Follower
Coaxial connection for RS200
How do I plug in my coaxial cable?
1 Reply
You can not. RS require a Ethernet connection. If you have a cable connection from the ISP, then you need a cable modem or if using something else, some coax to ethernet converter. Make contact with your ISP for help and information regarding connecting a wifi router system to there services.
