milop
Sep 05, 2026Aspirant
Difference between RS300 and BE9300
I must be missing something. As far as I can tell the BE9300 is the same as the RS300. So why is there a $30 difference in price? The BE9300 is $249 on Amazon and the RS300 is $279?
Thanks in advance,
Mike
- FrumpyGrandpaAspirant
The Technical Specifications are indeed nearly identical. The RS300 includes two statements that are not listed for the BE9300:
Thus, one might conclude that the RS300 is a more sophisticated product than the BE9300.
At least one reviewer says they are actually identical, just differently branded.
No idea if that is the case. But MU-MIMO and ODFMA are part of the WiFi-7 specification, so all WiFi-7 routers have those features.
