Ru123
Jan 08, 2025Aspirant
Disappearing SSID nighthawk be9300
I’m hoping someone here can help; every time I power cycle my router the SSID completely disappears and I can’t find it on any of our devices. Before turning off and on again everything is fine and co...
- Jan 09, 2025
After looking through the community some more I think this might be what’s happening; my isp requires vlan group tagging. I also tested and it doesn’t happen until i change that setting.
https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/RS280-Rebooting-kills-wifi-radios-when-VLAN-tag-group-is-enabled/m-p/2399684/highlight/false#M1537Hi Ru123, Thanks for the info. I've sent you a PM with the link for the tiral firmware that fixes this issue.
Jan 09, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Which RS model do you have? RS###
How is the wireless configured on the router.
Might pick up a USB to ethernet adapter if you have a computer that doesn't have ethernet port to access the routers web page.
I'd keep in contact with NG support and update them on continuing problems. Ask about an RMA.
- Ru123Jan 09, 2025AspirantFirmware is V1.0.1.60
We have fttp so the router is plugged in to the nbn box with a cat6 cable.
Its RS300
What is an RMA?
https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/RS280-Rebooting-kills-wifi-radios-when-VLAN-tag-group-is-enabled/m-p/2399684/highlight/false#M1537- BH_CJan 09, 2025NETGEAR Expert
- Ru123Jan 10, 2025AspirantThank you! That’s done it! Now to try and get UPnP to work with our Xbox’s.
