Ru123
Jan 08, 2025Aspirant
Disappearing SSID nighthawk be9300
I’m hoping someone here can help; every time I power cycle my router the SSID completely disappears and I can’t find it on any of our devices. Before turning off and on again everything is fine and co...
- Jan 09, 2025
After looking through the community some more I think this might be what’s happening; my isp requires vlan group tagging. I also tested and it doesn’t happen until i change that setting.
https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/RS280-Rebooting-kills-wifi-radios-when-VLAN-tag-group-is-enabled/m-p/2399684/highlight/false#M1537Hi Ru123, Thanks for the info. I've sent you a PM with the link for the tiral firmware that fixes this issue.
BH_C
Jan 09, 2025NETGEAR Expert
Hi Ru123,
Do you use the same SSID for all the 3 bands (2.4GHz, 5GHz, 6GHz)? Is that the SSID for all bands disappeared or just certain bands?
After you rebooted the router, you didn't see your SSID, but did you see the default SSID?
Ru123
Jan 09, 2025Aspirant
I have tried both ways, and they disappear either way. The default also disappears, there’s no way to find or reconnect at all without factory reset.
