BILL1836
Sep 25, 2024Aspirant
Do I have to use netgear wi name-BE9200
I do not like using the wifi name and PW from netgear. Can I change the PW and or the wifi name? I think the video said If I do not use the old wifi name I would have to reenter the new PW to all ite...
Sep 26, 2024Guru - Experienced User
I always use the same ssid/password so I can change routers and everything just reconnects without issues.
so yes, you can change it and its actually a great idea so changing in the future is easier.
