ShadowMario3
Sep 17, 2024Luminary
Does 6GHz channel interfere with 5GHz channels on an RS700?
I have two RS700 routers, both on firmware 1.0.7.86, with the second in AP mode. On the main one, I have the 5GHz channel set to 36 (since I noticed the neighbors are around channel 40), and the 6GHz...
- Sep 17, 2024
When the operation mode is set to "Up to 5.8Gbps", the router operates with 160MHz channel bandwidth. So if channel 36 is selected in this case, channel 36 ~ channel 64 are used for the 160MHz bandwidth, and channel 52 ~ 64 (U-NII-2A) are DFS channels. Then when the router detects radar signals in around those channels, it may switch to other channels.
BH_C
Sep 17, 2024NETGEAR Expert
ShadowMario3
Sep 18, 2024Luminary
Thank you for the explanation! Never realized this myself, but it's pretty easy to tell that this is exactly what's happening if you check the Channel under Advanced > Wireless Settings (5GHz). Think I'll lower it to "up to 2.9 Gbps" (80 MHz) so the overlap only goes from channels 36 through 48.
