royalcanuck
Feb 03, 2024Aspirant
Does the 10GB fallback to 2.5GB?
I've got an unmanaged 2.5 GB switch (TEG-S380) connected to the LAN 10G, but I can only get a maximum of 1GB. According to the LED description, it is amber if the "router detects a 5 Gbps, 2.5 Gb...
- Feb 04, 2024
RS700's 10GbE ports do support 2.5Gig connections.
Can you go to the RS700's Web GUI to check the Ethernet speed for the 10Gig LAN port? If you go to the Advanced tab from the GUI, you can see a dashboard and there is a tile named "Internet Port". Click on the "Show Statistics" button on the tile, it will pop-up the "Show Statistics" windows showing the physical link speed for each port. The 10Gig LAN port is LAN5, and you can find the link speed from the Status column.
If you only get 1000M/Full for LAN5, we will need to get some debug logs to find out the cause. We may need to prepare a debugging firmware to get proper logs.
royalcanuck
Feb 04, 2024Aspirant
I was looking for that page. According to my port statistics, my network connection speed is 2500M/Full, which is what I was hoping for. However, I'm not entirely sure if it has always been this way - I recently performed both a factory reset and a firmware update. Either way, thank you very much for your help!
BH_C
Feb 04, 2024NETGEAR Expert
Sounds good. Thanks for the update. If you run into this issue again, please let me know and we can look into it.
