Hutch927
Mar 16, 2026Follower
Feature Request: Add Static Routing Support to RS100 Firmware
I’m requesting that Netgear add basic static routing support to the RS100 firmware. The RS100 is marketed as a high‑performance home router, but it currently lacks the ability to define static r...
CrimpOn
Mar 16, 2026Guru - Experienced User
Hutch927 wrote:marketed as a high‑performance home router
It appears (to me) that the RS100 is the least costly and least powerful of seven WiFi7 routers offered by Netgear. Pretty obviously the "runt of the litter." I see no obvious reason for the RS100 not to provide Static Routes, which Netgear routers have provided for years and other RS models do. ( It would seem to be more trouble to remove the feature than to simply leave it alone.)
p.s. If the RS100 can still be returned, it might be worth considering. A feature change is not likely to happen quickly (if at all).
