Comelrose
Jan 15, 2025Aspirant
Firewall Protection - NETGEAR Nighthawk (RS700S)
I recently purchased the Nighthawk RS700S and understand it has a firewall through Netgear Armor. I know I don’t need another firewall, but I would like to purchase an additional firewall for external...
Comelrose
Jan 17, 2025Aspirant
More consumer grade. Realize NETGEAR has one internal, but just want local management for home network. Looked at Firewalla purple (recommendations say it’s crap). Need something that’s compatible with NETGEAR maybe where I don’t have to buy a separate WAN to be compatible. I’ve already dropped $600 and don’t feel like dropping another $600 for a firewall. Help??
Jan 17, 2025Guru - Experienced User
There really isn't much that will "integrate". there's armor but its pretty minimal as well.
I'd probably look for a used PC that you could install pfsense to and run your own firewall. Plus there's other open source firewalls out there if you have a PC to install them to.
