JamesL1979
Dec 06, 2025Apprentice
Fix for Access Control Blocking?
I had this issue with my RS300 after firmware upgrade that seems to have broken the Access Control page. One of the symptoms is devices being shown blocked, but not on the connected devices page. ...
Dec 06, 2025Guru - Experienced User
What browser are you using? Does this happen in other browsers?
What FW version was the RS updated too?
JamesL1979
Currently using Vivaldi which is chrome based, I think it was working before the upgrade, also the firmware seemed very old before I upgraded which was odd because automatic update was enabled.
The current firmware is V1.5.0.22. I expect to receive a new device for the network next week so I can do some testing to see if the behavior is as expected or not.
- FURRYe38Dec 06, 2025Guru - Experienced User
Might try FireFox or MS Edge to compare results as well.
