Dummy001
Jul 08, 2026Tutor
Fun with lights.
So, except for my printer (white HP) my desktop theme (I have 2 Dells, 9020 and a 790 - Hey, if it's not broke, don't fix it. They work awesome) Anyways, my theme is Black with Blue lights....except ...
Jul 08, 2026Guru - Experienced User
Seems like you wanted to change the color of the LED output?
Not sure if that model has LED adjustments on the routers web page. Maybe all ON or power only ON if you don't wanna LEDs to all be on.
Some can use post it notes to cover the front if needed.
Not sure what DR is.
Jul 09, 2026Guru - Experienced User
FURRYe38 wrote:Not sure what DR is.
"Dr. Teals bath soap" Just an extra capital...
Dummy001 wrote:my lights on the RS100 are blue!!
Creative!
Keep in mind that the LEDs have two colors - amber and white. The improvised filter might make it hard to distinguish them.
- Dummy001Jul 09, 2026Tutor
I believe the amber light is the top one. Only amber when it's powering on or rebooting. And yes, creative...thanks! I had originally thought of cutting the bottom of the bottle off and slipping it over the router. They appear to be the same size. But then I thought of a lack of ventilation...heat is electronics enemy. This was the next best thing.
- StephenBJul 09, 2026Guru - Experienced User
All of them can be amber in some situations. See page 12 of the manual:
- https://www.downloads.netgear.com/files/GDC/RS90/RS100-90-70_UM_EN.pdf
