Dummy001
Jul 08, 2026Tutor
Fun with lights.
So, except for my printer (white HP) my desktop theme (I have 2 Dells, 9020 and a 790 - Hey, if it's not broke, don't fix it. They work awesome) Anyways, my theme is Black with Blue lights....except ...
Jul 09, 2026Guru - Experienced User
FURRYe38 wrote:Not sure what DR is.
"Dr. Teals bath soap" Just an extra capital...
Dummy001 wrote:my lights on the RS100 are blue!!
Creative!
Keep in mind that the LEDs have two colors - amber and white. The improvised filter might make it hard to distinguish them.
Dummy001
Jul 09, 2026Tutor
I believe the amber light is the top one. Only amber when it's powering on or rebooting. And yes, creative...thanks! I had originally thought of cutting the bottom of the bottle off and slipping it over the router. They appear to be the same size. But then I thought of a lack of ventilation...heat is electronics enemy. This was the next best thing.
- StephenBJul 09, 2026Guru - Experienced User
All of them can be amber in some situations. See page 12 of the manual:
- https://www.downloads.netgear.com/files/GDC/RS90/RS100-90-70_UM_EN.pdf
