Trainman52
Jan 01, 2025Tutor
Guest Network SSID Not Appearing
I've been trying to set up the guest network 2.4 on my BE9200 (RS280) using WPA2. The process completes and the App shows the network up and running, but it does not appear on any of my devices. If I ...
Trainman52
Jan 06, 2025Tutor
I haven't gotten a chance to try it with the web interface. The network has been relatively stable since I removed some devices. I don't want to press my luck but will get to it eventually. Every reboot creates a new adventure. Thanks
Jan 06, 2025Guru - Experienced User
Is IPv6 or Protection Engine enabled on the RS router?
- Trainman52Jan 07, 2025Tutor
How would I determine that?
- FURRYe38Jan 07, 2025Guru - Experienced User
Router web page under Advanced tab/Security.
