nteambx
Feb 05, 2024Aspirant
Having issues with connecting to the internet on 10G port from ISP: Optimum
Having issues with connecting to the internet on 10G port from ISP: Optimum. The 10G port is in bridge mode where it is suppose to give a public ip. The router is not able to get a lease from DHCP. T...
Feb 06, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Plug in and turn on modem. Wait 1-2 minute for it to connect.
Turn on computers and rest of network.
Be sure the ISP doesn't have any specific WAN side configurations that maybe needed. Ask them about this. Some require PPPoE configurations.
Check for any MAX Spoofing as well.
- nteambxFeb 06, 2024Aspirant
Altice Gateway 6 Max, xsr150dx, Optimum. Using cat8 wire.
Tried all those steps already.
There is no login required, I am able to get internet when directly connected to laptop. ISP turned on bridge mode.
Also tried spoofing mac of link on laptop.- FURRYe38Feb 06, 2024Guru - Experienced User
Is the cable STP or UTP cable? STP being preferred here.
Does the RS show a connection on the RS web page under Advanced tab/Show Stats button?
Can you post a screen capture of this page?
Wondering if the ISP could put the gateway back in router mode and then use the router DMZ for the RS700...
STP, it works on the LAN ports of the modem (1G ports). Just not on the bridge moded port.
I doubt I can get them to set up the DMZ approach. The tech support isn't really tech support. Non tech savvy people.
