jamielou
Sep 10, 2025Aspirant
Help please rs300
Nighthawk BE9300 WiFi 7 Router (RS300) was purchased 8/13/25. I previously had a ax5400 that was wonderful (no drops) but in its 4th year. Upon downloading. I began dropping internet service multipl...
DarrenM
Sep 10, 2025Sr. NETGEAR Moderator
Have you updated to the latest firmware? Do the drops only happen on wifi and not via Ethernet? Does this only happen on certian devices? You may also want to check if your router has Protection Engine and if it does try to disable it in the router settings Advanced Tab/Security/Protection Engine.
Thanks
Darren
