jamielou
Sep 10, 2025Aspirant
Help please rs300
Nighthawk BE9300 WiFi 7 Router (RS300) was purchased 8/13/25. I previously had a ax5400 that was wonderful (no drops) but in its 4th year. Upon downloading. I began dropping internet service multipl...
jamielou
Sep 18, 2025Aspirant
Yes. firmware is updated automatically (that was what I was told by a call to netgear. Then, support checked and adjust a few things 2 weeks after 8/13/25. I use wifi not ethernet. I rebooted system a few times. I will check router settings but I have used netgear router previously 3 years old and this replacement is giving me fits.
Sep 18, 2025Guru - Experienced User
What FW verison is loaded on the RS router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 or Protection Engine enabled on the RS router?
jamielou wrote:Yes. firmware is updated automatically (that was what I was told by a call to netgear. Then, support checked and adjust a few things 2 weeks after 8/13/25. I use wifi not ethernet. I rebooted system a few times. I will check router settings but I have used netgear router previously 3 years old and this replacement is giving me fits.
- jamielouSep 18, 2025Aspirant
1.0.1.90 firmware........ 2018 spectrum /charter modem e3itzv1 docsis 3.1
I have a
StarTech.com 6ft CAT6a Ethernet Cable - 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord - 10GbE STP Network Cable w/Strain Relief - Black Fluke Tested/Wiring is UL Certified/TIA (C6ASPAT6BK)
- FURRYe38Sep 18, 2025Guru - Experienced User
