Xeroid5
Oct 10, 2026Follower
How can isolation be disabled?
I have same issue using RS140 router … want to remove network isolation between the main network and the guest network. How can isolation be disabled?
Oct 10, 2026Guru - Experienced User
Xeroid5 wrote:I have same issue using RS140 router … want to remove network isolation between the main network and the guest network. How can isolation be disabled?
Guest is isolated, but the IoT network is not. So one option is to use that.
