Bodoque
Apr 14, 2025Aspirant
How to find BE9300 Tri band wifi router IMEI?
I'm trying to find the IMEI number that's associated with my router I don't see it on the router itself, on the app or when I log in to Netgear as an admin. Does anybody know where to find the IMEI if...
Bodoque
So if I want to check if the BE9300 router is compatible with Verizon business wifi you are saying I can't check if it's compatible since the router doesn't have an IMEI to input when prompted by Verizon to put one in?
ShadowMario3
Apr 15, 2025Luminary
If the internet you're looking into requires a SIM card (mobile internet), you'll need a hotspot like the Netgear Nighthawk M6/Pro. If the internet you're looking into doesn't require a SIM card, you do not need an IMEI number whatsoever.
